The grinding from my bottom bracket is now loud enough to scare the local wildlife, so I've decided to have a go at replacing it. It's a Shimano cartridge type, and I've had a look on various websites so I think I know what I'm doing, but I'd appreciate it if some experts could glance over my checklist and tell me where I'm going wrong:
- Remove crank arms
Remove the crank bolts with a hex key. Screw in the crank extractor so it's tightish. Then tighten the inside bit until the arm comes off. - Remove the cartridge
Align the bottom bracket tool, then use a big spanner to undo the screw threads on each side (non-drive side first??) - Clean everything
- Fit replacement cartridge
Grease up the threads, then screw it into place (again, non-drive side first??) - Refit crank arms
(Is this just a case of screwing in the crank bolts?) - Ride away and hope nothing falls off
