BB and Chainset replacement
Hi guys
I have a friend who has worn chainrings and a bottom bracket that needs replacing.
Currently he has a SRAM VIA Centro power spline, 48/32T chainset and a
SRAM, PG-1030, 10-SPD, 11-36T
Bottom bracket is a Truvativ 68x118 powerspline.
He said he only uses the 48t ring. He does not use the 32t. It’s a Boardman Hybrid bike.
He has a 10 mile exercise route he does on a daily basis. Nice flat tarmac cycle route.
Ideally if he could lose the 32t and go for a single that would suit him better.
If he has to stick to a double he doesn’t mind.
What are his options in replacing the chainset and bottom bracket.
From reading square taper seems to be the most reliable.
Any recommendations?
I like Skol
A Minging Manc...
I think in his position I would reassess the ratios completely.
Front would stick with a double but go to something like a 36/52 and at the back change the cassette to something like an 11-26 to give a closer set of ratios while still keeping the small chainring for when the gradients increase.
Cycleops
Accra, Ghana
He could go with either a square taper BB like the good old Shimano type or a more up to date one like Hollowtech which has outboard bearings and is lighter. ST will be cheaper and longer lasting.
C
Commutering
Member
Thanks guys.
I dont even know what to look for in regards to a square taper 36/52?
I understand it will have to be a road chainset?
I did some reading on various forums and the general consensus was its a headache putting a road chainset on a mountain bike.
I take it this is where the Hybrid bike differs as it already came with a road chainset?
I would rather stick with square taper for him.
