Basic Question About Ferrules On Gear Outer Cables
woodbine
Bristol, UK
I have a 25 year old MTB with Deore derailleurs and original Shimano SIS SL MT60 lever shifters. The bike was only used for the first 5 years of it's life and stored for the last 20 years. It still has all the original cables and outers.
I'm in the process of replacing the gear cables, but the originals were fitted without any ferrules to the ends of the cables. I have bought some metal ones. The new outers are Shimano SP41. I know I should put the ferrules on the outer ends where they go into the frame stops, but should I also add ferrules to where the outers enter derailleur and shifter? Or do the entrance apertures to the derailleur and shifter act as ferrules?
THESE ARE MY FERRULES -
10 x BIKE BRAKE & GEAR OUTER CABLE FERRULES 4mm METAL BICYCLE END CAPS | eBay
Yes. Ferrules should always be put on gear cables.
Davidc
Somerset UK
Wot Smokin Joe says, and in addition the lever and dérailleur cable entries should be big enough to take the outer with a ferrule on it.
midlife
You don't always need to have a ferrule on the rear mech depending on make / year. Mind you I'm going back more than 25 years LOL
Shaun
raleighnut
If you are using dedicated gear cable outer (Linear twisted, not the 'universal' spiral wrapped stuff) then the correct ferrules will be small enough to fit in to the shifters as the outer is thinner.
