noelmg
- Mansfield, Notts
Well I think it's called a bash ring. It's the plastic ring on the front gears on the extreme outer of the gears, near the pedals. It has 4 philips head screws into lugs holding it on. The plastic on 3 of these has broken off so it is only being held on by one.
Can I just remove this or does it need replacing? Hopefully the derailleur will keep the chain from coming off if it is adjusted properly, and I only ride in shorts so won't have to worry about trousers getting dirty. Is there a more critical function to this?
Cheers
Noel
Cheers
Noel
