Barrel adjusters
I'm in the process of converting my flat bar bike to drops. Are there any good types of barrel adjusters I can fit to the bike. Some came with the sti's but this would mean drilling holes into my frame I don't really want to do that and I would need some more for the brakes. They're 'v' brakes BTW.
In-line cable adjusters are what you need, try a Giant cealer.
STI brake levers are not compatible with V brakes btw.
dodgy
I think Mickle might be referring to the leverage offered by STI levers, there are incompatibilities that cannot be resolved just by correctly wiring them up.
Dave
Marie Attoinette Fan
Cheers again, I fitted the in-line cable adjusters last night they done the job perfectly the gears seem OK. I realised however I needed another couple for my brake cables, popped back to the lbs they had none, I must of took their last pair. I then popped accross to another lbs and they had none either but then they referred me to their work shop the mechanic came out with exactly what I needed minus the plastic bits but I had them from my last set, so no worries. I asked what I owed him but he said don't worry about it :smile:. So here's a shameless plug for Velo Ecosse
