Holdsworth
- Crewe, Cheshire
Typical! I just have to sit and tinker with the components on my new bike and I end up breaking it somehow!
Haven't even had my EBC Country Traveller 24 hours and I have done something that makes it unrideable. The problem is with either the cross-top lever for the front brake or the barrel adjuster that locates into it. What I was doing was trying to adjust the yoke cable so I could get the brakes unhitched a little easier for when I would need to remove the wheel. I then backed off the barrel too far and it must've come off the thread. Me not knowing I kept the brakes hooked up and therefore the cable was taught and I tried to thread the barrel and screw back on. No lukck and it just jammed. Wouldn't budge either way then so I had to use some pliers to back it off again!!! Bad I know but I didn't think at the time. Then I remembered to unhook the cable for easier maintenance and tried again. But again nothing, it just threads in a few turns then stops, did repeatedly for around an hour to try and get it in but it wasn't having it.
Result is that the front brake is inoperable so I cannot even use the bike now!
So I think that either barrel adjuster is knackered or the thread has been stripped from the brake lever. Either way I am seriously not happy for me to have done this to my brand new bike
Need some help on what to do asap.
