Just bought a new set of bar end shifters because I wanted a friction option for the rear. I've only done the front changer so far. Took the old one off and put the new one in. Inserted the smooth new cable into the shifter and it glided through the outer cable housing perfectly. Attached it to the front changer. The shifter barely moves. I can just about get it to move onto the middle ring but it refuses to get on the big ring and the lever is very stiff.
Obviously I've played around endlessly with pulling the cable into different positions. As soon as I release the cable from the front changer, the shifter moves perfectly. I just don't get it. Spent two hours repeating everything and checking the shifter is correctly in its housing. The only thing I haven't done is change the outer cable which came with the shifters (because that would mean taking the bar tape off). I can't see how changing the outer cable to the one that came with the set would make much difference as the cable glided through the original outer cable effortlessly. I am at a complete loss to understand what's wrong. Can anyone help?
Many thanks, Tim.
Many thanks, Tim.
