Banging noise uphill?
Alex McCarthy
Tunbridge Wells
Have recently bought a secondhand steel frame road bike to get back in the saddle after 8 years of not being on a bike! It's absolutely fantastic being back on a bike.
Having done just over 25 miles in my first week, I can't help but notice that when going uphill and putting some real effort in, I hear a banging noise from either the frame or front crank, I can't quite work it out, any suggestions?
helston90
Eat, sleep, ride, repeat.
Cornwall
Bottom bracket?
A
Alex McCarthy
Tunbridge Wells
Right, will do! Will take it to my LBS as the technical side of things are not my strong point as you may have gathered.
It's probably due a few new parts over the next few months as it is so will get it overhauled ASAP.
Thanks guys
Bodhbh
Thanks for all the help, I'm looking at parts as I write this.
Will my bike be rideable for the next week or so before I get the new component fitted?
Thanks
I always ride it for few weeks before I get sick of the knocking and get a new bottom bracket- this has been happening quite a lot using rubbish HT2 Deore bottom brackets.
albion
If it has a freewheel it often means the rear axle is near broken.
Noise can be deceptive.
gbb
Peterborough
Explain please? Newbie to this.
The noise comes only when cycling uphill at the top of my pedal stroke?
I was thinking In a similar vein to albions, but not the same.
Freehubs are occasionally prone to sticking, I had a similar thing when I reallyput pressure through the cranks..the freehub slips momentarily and you get a bang as it re-engages under pressure. Sometimes, but not usually you'll feel the crank slip as it failed to engage at the freehub..but not normally because it happens so quick. But this is with freehubs, not normally with freewheels.
I had an occasional sticking freehub when a previous bike was nearly new, but it passed after about a month, never to re-appear.
Alternatively, a BB on the way out can bang, as the balls move out of position in the races, bind against the next ball, then bang as they release again under some considerable pressure...this would be a more likely reason than the freehub.
Happening when the cranks at top of stroke ? That could be when maximum force is beginning to be exerted,, a most likely time for any stress to show itself.
tyred
Ireland
I had that problem with a single speed freewheel and it took me ages to figure out what was wrong. A spray of WD40 into the freewheel body resolved it.
The OP says his bike was second hand, if it was lying in someone's garage for 20 years, it may be worth spraying a little WD40 or similar into the freewheel body but be careful not to get into the wheel bearings.
  • Like
Reactions: gbb
Noise can be deceptive; it can be comming from a variety of areas, it could be the pedals, the headset, BB, etc. I have to get to the bottom of a noise like that myself; my bike makes an audible click when I throw it from side to side on a uphill sprint, silent otherwise, I'm guessing its the headset but thats only a guess.
