You need 5/32" if memory serves, but I might be wrong. I usually use these:
http://www.ebay.co.uk/itm/1-PR-BICY...sleisure_cycling_bikeparts_SR&hash=item3cc018 Tell the seller what they are for, this bunch know about bikes! If you prefer loose ball bearings make sure you get the hardest grade and by the pack ( Cheaper but, by the time you need to do this you are usually in deep trouble and have another four or five frames hanging up ready to start on!) Have a look here:
http://www.ebay.co.uk/itm/Weldtite-...arts_SR&var=&hash=item6fc36b26ca#ht_979wt_879
Beg or borrow a micrometer (cheap as chips!) and measure things you take off. Like most things worth the effort the ball bearings on bikes stayed pretty much standard for a hundred years or so. (You have already learned rule 1, by the way, - keep all the old bits until you have checked them against the new bits!)
Take the time to look here :
http://sheldonbrown.com/ . Sheldon Brown (now sadly dead) knew just about everything worth knowing about bicycles and this site is a mine of information. (Don't be put off by it being an american site, he enjoyed british bikes and you will find a great deal of info here.
