Hi,
Noticed today my back wheel has started wobbling. What I mean by that is if I lift the back of my bike up so the wheel is off the ground, I can wobble the wheel inbetween so it touches either brake pad, its a loose wobble as well, i.e. no real resistance. Only other things is as the wheel moves and I think the chainset moves a little in the opposite direction, almost like the axel is snapped, although it might be my eyes playing tricks with the wheel moving. The wheel turns fine, I did manage to limp / cycle into work today so I can get it repaired.
The frame is ok, its solid / rigid no cracks or anything I can see. The wheel is properly screwed in / attached with those allen key things to the frame, so the problem I think lies with the wheel itself, is that where the hub is?
Just wandering if anyone can suggest what might be going on? I'm guessing this problem is terminal for the wheel. I think it should be possible to get a new wheel and keep my rear cassette? Gonna be taking it into my lbs so trying to idea whats going on.
Thanks for any help,
Jon.
Jon.
