I heard a bit of a clunking noise from the front of my singlespeed bike today. It sounded like a loose headset but the headset turned out to be properly adjusted and in good condition.
Further investigation revealed that the problem was the front wheel.
Take a look at these 2 photographs; specifically, the gap between the brake block and the rim as I pushed the tyre to the left and right.
There was more than 2 mm of movement in the rim.
I took the wheel off and discovered that the lock nut had come loose on one side. The hub has sealed bearings and they were okay. All I had to do was to correctly adjust the hub and tighten the locknut. (I had mislaid my cone spanners and tried to do it without them, which resulted in an over-tight hub and a wheel that would barely turn! After finding the spanners, it was easy to adjust things properly and lock them in place.)
