Axles and Cones Spares
Alembicbassman
Confused.com
I removed the rear axle from my fairly new bike (out of warranty).
The drive side cone is pitted, the non-drive side is fine. The hub races are fine.
I suspect that the fault was present from installation.
I'm getting a lot of conflicting advice about how to proceed.
I've tried getting a replacement cone, no luck.
Now I've been told a full replacement axle assembly with cones and spacers may not be possible.
The races take standard 1/4 balls and the freehub is Shimano 105 10 speed.
heretic
In the shed
Replacement cones are made by Wheels Manufacturing. Have a google and compare the one you've taken off. If it's even halfway modern the LBS should be able to provide straight out of the spares box.
Alembicbassman
Alembicbassman
Confused.com
I went to 4 LBS today
Planet-X - Too busy chatting to serve me
Fosters - No cones in stock only cheapo Weldtite axle assemblies
JE James - No cones, not even any axles in stock
Universal Cycles - Nothing that fitted existing axle
Maybe I need to move back to London as it's crap for bike shops up North
Gerry Attrick
You are learning fast!
Try SJS Cycles. They keep all kinds of bearings etc.
http://www.sjscycles.co.uk/
Alembicbassman
Alembicbassman
Confused.com
Would you believe it, Halfords had one and gave it me for nowt.
Not an exact match but so close as not to make any difference, no extra washers or spacers required and the rubber gaiter fits on it a treat .
Works fine now all put back together, runs smoother than the pitted one for sure.
Great. Pack it with quality waterproof grease - like Finish Line....you'll be fine.
