I have Avid BB5 disc brakes on the front.
Last night i tried to change the pads. The inboard pad [non-piston, closest to the wheel] came off as per expected. The outboard pad [the one in contact with the piston and the one that moves when you brake] did not come off as expected. i did try to prise them apart with a knife but it would not come apart. On looking, it appeared that the outboard pad had been fused to the piston/caliper.
Could this be due to heat build up? i dont brake heavily at all and its a hybrid bike.
Has anyone else experienced this problem?
I am using semi-organic pads if that makes any difference?
Thanks
w
Thanks
w
