I like Skol
A Minging Manc...
- Sunny Ashton-under-Lyne
I don't think it is just me as this appears to be getting more common in other posts from forum members I am reading on cyclechat. I initially thought it was just down to a daft update on my Kindle Fire as I don't suffer the same issues when using a Windows10 PC to post but the fact it seems to be affecting others makes me wonder if it is a forum software problem?
Just for example, here is a post I made earlier....
And here is the same post but without my proof reading corrections.....
***Are you not mistakenly confusing the condensation effect with the actual coldness?
Condensation is an indication of moist air and can occur when there is a temperature difference. It is likely that your fridge is as cold or colder than the shop drinks chilled but is just much less moist due to design and less regular opening of the door. Also, the wet cans may feel colder to the touch as the water droplets will help form a more efficient heat transfer to Rob the best from your hand and transfer it into the chilled can, thereby giving you a cold aching hand and beer that warms up more quickly than a dry can!***
That is not a particularly bad example, there have been cases where I have to correct multiple words in a sentence. Also, if I spot it when the word changes (after I insert the space) and then hit the backspace button
the word reverts back to the intended word as typed and the space does not delete
It has got to the point where I have to carefully reread every post I make to check the predictive text function hasn't changed the correctly spelled and grammatically correct words for something that renders sentences completely meaningless! The annoying thing is that if I click back on the altered word when proof reading, the 1st suggested alternative is the one I originally typed so it knows what it has done and I know I haven't mistyped.
Is it the forum at fault or my Kindle (presumably using a variant of Android)? It is getting a bit tiresome now having to continually fight the software to prevent it making a dogs dinner of my carefully planned and perfectly executed literary masterpieces…...
Condensation is an indication of moist air and can occur when there is a temperature difference. It is likely that your fridge is as cold or colder than the shop drinks chiller but is just much less moist due to design and less regular opening of the door. Also, the wet cans may feel colder to the touch as the water droplets will help form a more efficient heat transfer to rob the heat from your hand and transfer it into the chilled can, thereby giving you a cold aching hand and beer that warms up more quickly than a dry can!
