Attention Airnimal owners
Hello all - just an enquiry about Airnimal sizing - I know these are flexible bikes in terms of fit but I'd like to know how flexible please.
I own a small airnimal chameleon and at 5'6" I can get away without a layback and with a 100mm stem which gives me my preferred seatpost to bar length of 520mm and a fairly untwitchy ride.
One of my friends - 5'11" - is looking to get one and Airnimal say that height is on the cusp of the smaller and larger frames. He'd be looking at a seatpost to bar length of 550mm. With the smaller frame that would mean a whopping great 120mm stem and at least a 10mm layback - or an even bigger layback and a shorter stem. I'm guessing the larger frame would be a better fit. Problem is he's temtped by a smaller one on the bay at the moment.
As we are all suckers for bargains/a bunch of cheapskates* my questions are how big is your airnimal, and how big are you? How well does it work for you?
*delete as appropriate
Ian H
Ancient randonneur
Doesn't the bottom bracket shell sit behind the seat tube on a Chameleon? If so he could get away with more lay-back - in fact might need it. He ought to measure a current bike and see how far back the saddle is in relation to the BB.
potsy
Rambler
My Armchair
Aw poo,I thought this was another thread where we all post pics of our cats/dogs
Kirstie, greetings. I think your friend should look for the bigger frame; I am 5ft 9" and found the smaller Chameleon frame ust a little small, using butterfly bars and the standard stem. However, at my height it is very marginal and not a real issue. I think at 5 11 your friend would find it a bit cramped, even with the layback/stem adjustments you are thinking of - which might compromise road handling and ride quality. I leave that angle to more expert riders! I would recommend you take the advice of Airnimal themselves who are good responders to any query. Good luck!
Solar Panel Phil
