ATC2K for paintballing?
Cab
Cambridge
Going to a stag do at the weekend, paintballing for the most part.
How would you carry the ATC2K for such a trip? Would you rubber band it to the gun? To your head? Whats my best bet?
downfader
extimus uero philosophus
'ampsheeeer
If you know the diameter of the barrel then you can use thehandlebar mount to apply is (just screw it on to the side so you can view where you fire).
If you find the barrel is too narrow you will need some foam, rag or tissue to wrap around to secure it firmly. It shouldnt be able to wobble or swing around.
Failing that use the short velcro and the helmet adapter. Good luck!
