Are there any special underpants that can be worn when cycling?
Cyclopathic
Leicester.
My cycle use is fairly casual but I do like to try and get out on longer runs when I can to get a bit fitter. I do not wear any lycra gear favouring instead loose fitting comfortable things I can wear when not cycling. However I do find that my bum can get a bit sore after a long ride (I am currently trying out a few different saddles to help combat this) and being a bloke dangly bits can get a bit squished if not careful.
So are there any pants that anyone could recomend that perhaps smooth out pressure from seams and such and that will also keep everything snug and out of harms way.
gaz
Cycle Camera TV
South Croydon
Just buy some padded shorts. They are lycra but just wear your baggies over the top. Very comfortable
Mad at urage
Not comfortable at all if you are allergic to lycra.
