Chris S
- Birmingham
My bottle-dynamo gives much more light when I spin the wheel backwards instead of forwards. Is there anything that I can do about this?
You could mount it upside down to normal, it'd never know.From what I recall of using them many years ago; when it was in the stowed (not on the tyre) position, it was held in place by an sprung-loaded mechanism
When released to rub on the tyre, it sprang in, under tension.
Surely this indicates the relevant seat-stay to mount it on?
You could mount it upside down to normal, it'd never know.![]()
Really, in this day and age? I would just junk the dynamo and buy some LED lights and a couple of rechargeable batteries. Far more versatile, will easily swap from bike to bike, stay lit when you stop, bright and not very expensive. My front light is from a cheap Reebock branded set that I bought about 4 yrs ago and seems to be indestructible and the rear lights are a pair of smart lights which again have been in use for a couple of years in all weathers.My bottle-dynamo gives much more light when I spin the wheel backwards instead of forwards. Is there anything that I can do about this?
Don't be daft - all the electricity would fall out.
GC
Unfortunately there is just one mounting-lug on one side of one fork.Ride backwards?
Can the dynamo be fitted to the other side, then it would rotate in opposite direction?
Keith
Batteries last weeks between charges and I carry a couple of spare batteries just in case but they start to noticeably dim long, long before they stop working so I have yet to stop and change batteries out on the road. lights cost less than £25 and batteries are not dear either. I use Sanyo Eneloops as recommended by others on this forum.
I hear what you are saying and I am sure that quality modern set-ups are 'light' years ahead of the stuff most of us are basing our opinions on but, how much does such a set-up cost (including having a wheel built with the dedicated hub)?Ahh I hear the words from someone who has not experienced modern dynamo lighting. Admittedly mine is a dynohub not a bottle dyno. But I am so impressed that next year I will be having my main commuter converted as well. They knock the socks off all my other lighting (including magic shine), stay on for four minutes after I stop, and the rear has a smart brake light (this function will not work with a bottle dyno).
The lights were £160 from Germany, that was a rack mount rear with smart brake light, a seat stay rear, and a absolutely cracking from light with a beam pattern to die for (the light goes on the road exactly where you need it, no overspill at all). All needed as I ride country roads without street lighting at very unsocial hours.I hear what you are saying and I am sure that quality modern set-ups are 'light' years ahead of the stuff most of us are basing our opinions on but, how much does such a set-up cost (including having a wheel built with the dedicated hub)?
The OP sounds as though he is struggling with a product straight out of the 70s or 80s and based on that assumption I will stand by my advice to chuck it in the bin and get some 'light' modern LED lights.
