derrick
- On the edge of London
This is for a road bike, there is a big difference in price on brakes, what are you getting for your hard earned wedge, is just lighter or is there more to it?
Don't listen to Mr high blood cell, he only uses the cheap stuff. [wonder if he will flog my better half a pair of 202 tubs cheapThis is for a road bike, there is a big difference in price on brakes, what are you getting for your hard earned wedge, is just lighter or is there more to it?
Have you got any experience of cork pads for carbon rims, if so, are they any good please?I think I run some reasonably high end brakes (not sure if they are what you consider to be better)
on my Tarmac I have TRP full carbon R950 SL
http://www.trpbrakes.com/category.php?productid=1011&catid=183&subcat=0
on my Di2 Venge I run TRP R979 EQ
http://www.trpbrakes.com/category.php?productid=1135&catid=183&subcat=0
On my CVNDSH Venge Im supposed to run SRAM rim brakes, but don't cos SRAM have recalled them
I purchased TRP brakes after being unimpressed with the braking experience I was getting on wheels with carbon braking surfaces in the wet. I was advised to try them by someone at Zipp and I generally find them to be better in this regard which is why I continue to use them.
The appearance of the brakes and the weight also appeal to me but that's secondary.
Lol...."squeak like a pig" I recently bought a set of Cole pads and am very happy with the wet performance so far.I use cork pads extensively during winter as they seem to stop in a more controlled manner in the wet, the braking surface used by zipp can be a little grabby in certain situations. by contrast Cork pads seem to be slightly worse in the dry and squeal like pig being strangled, they also have a higher wear rate from my experience.
I can send you a picture if you wantYou have working SRAM red brakes in your possessionnow I have heard of everything.
