Apply brakes....scraping sound from rims.
handsome joe
Every time i initially apply my front v-brakes i get a scraping sound. By the way i have just replaced the brake pads as i thought it could be them but the sound is still there. Are they poor quality wheels?
Tynan
e4
dirty rims? might be worth wiping them with a damp cloth
I'm assuming that when the brakes are pulled that only the face of the brake pads are touching the rims
Radius
SHREDDER
London
I thought dirty rims too, or pads could be contacting tyre as well as rim, although you'd probably notice that...
H
handsome joe
Cheers for all the advice. Had a closer look again tonight and found pad incorrectly contacting the rim. The pads are slightly tilted at an angle. The front of the pad is coming into contact first if you get what i mean. I had a little wiggle and everything seems ok. Talking of dirty rims. I've got salmon pink kool stops and was amazed at how dirty they are after a week of use. Makes me wonder about all the crap i breath in everyday!
summerdays
Cycling in the sun
Bristol
Tynan said:
most of it is stuff off the road I think, it's dirty down there
No - most of it is off your wheel.... I have disk brakes on one bike and v's on the other... the difference is huge in how dirty the rims get.
jimboalee
Solihull
The blocks are supposed to have a "toe-in". They contact at the trailing end first. The application of pressure pulls the brake mechanism into square - or close to it.
No "toe-in" = squeal. The whole face of the block contacts simultaneously and the block judders at a high pitch because the leading edge is being dragged onto the rim's brake track.
The usual "Toe-in" is 3mm over a 35mm long block.
Every time the blocks rub on the rim, they wear. Even a pink block will give off dark grey 'squidink' if there is moisture around.
I prefer the blocks to wear in preference to the rim. What I don't like is the mess on the rim, especially when it rains and the black ooze trickles down the forks and seatstays.
vernon
Harder than Ronnie Pickering
Meanwood, Leeds
I'd not worry about the crap that you breath in. The black/grey scog that you find on your blocks and rims are the rims themselves albeit microscopic particles of rim.
Tynan
e4
yes, the rims get it from the road though yeah?
I assume the rims don't grow dirt
summerdays
Cycling in the sun
Bristol
Yes they do - its called metal and rubber
jay clock said:
Most of the dirt is microscopics bits of rim.
+1
Honestly ... you should see the difference between the two rims of the bikes. Touching the wheel of the bike with disk brakes is so much nicer as you don't automatically get covered in that grey stuff. Yes it still picks up stuff off the road but not to the same quantity and the particle size is probably bigger?.
Tynan
e4
so all the muck on the rest of the bike, especially near the road is from the brakes and rims?
e-rider
Banned member
South West
I've just fitted a new pair of wheels, so I thought it would be a good idea to fit new pads too.
Mine are also quite loud and make a sort of scraping sound. Both the rims and blocks are brand new and clean. I just thought it must be either the new rims or pads and that it should go pretty soon. Anyway, 150 miles later and it's still there!!!
yenrod
'Bits' in the grooves are a painintheass - and can remove your rim at a faster rate than usuall..
Get in those grooves (brake blocks) folks and clean 'em out !
