amasidlover
- Gatley
My son's Boardman CXR 8.9 (bought second hand) came with Apex 1 x 11 and the right hand shifter has started having significant issues - the cable end managed to pop out of the red retainer in the shifter yesterday; apparently this occurs on these shifters if you apply too much force e.g. try and change gear while stationary, although apparently my son doesn't do this (and to be fair I've never seen him do it). Plus the shift down has never quite been reliable it can take several attempts before it will shift one sprocket down the cassette.
I've only ever run Shimano before so I don't know how close to normal the shifting is, but from reading forum threads it sounds like SRAM can be a bit clunky than Shimano but is usually reliable.
So I have two questions...
1) Would a change in shifter be sufficient to fix the issues or could this be a faulty / worn derailluer that requires more force than normal (the cable is new and the the derailleur is clean).
2) What shifters are compatible with the Apex 1 x 11 rear derailleur? If it improves the shifting I'm happy to pay a bit more to get a Rival or Force (suspect Red is too expensive) shifter, but I'm not clear on whether the hydraulic brakes are all compatible or whether I can use a Rival 22 right hand shifter (I can't seem to find Rival 1 x 11 shifters on sale).
