Anyone local to Chesterfield help please?
Hi, i have a whyte 801, loving it but my front brake seems to be weak and makes an awful noise when i apply it. This is my first bike with hydraulic disk brakes and have been told i may have air in the line. They are tektro brakes but i have no idea on how to bleed them. Is there anyone or anywhere other than J.E James who can fix this for a fair price? The last thing i want to do is start fiddling then make it worse :sad:
lpretro1
Sounds like worn/contaminated pads to me. Replace pads, clean rotor and fit new. Do this before you start down any other route.
PradaMTB
PradaMTB
Regular
Its had its free service and then i took the front wheel off one day and ever since its been making the awful noise like a warped disk on a car, it doesnt lock up whatsoever and if i didn't have a good rear brake, i'm pretty sure i wouldn't stop with the front fully applied...
Big_Dave
The unlikely Cyclist
You've pretty much answered your own question, I would double check the wheel has been refitted correctly, and might the need caliper realigning, I'm only in Blackwell if you're stuck.
