Fastpedaller
In Oct our Ford Ka+ just scraped through the MOT test when we found the headlight 'adjustment motor' wasn't moving one headlight. This feature is where (if there are passengers in the rear seats) the headlights need adjustment by moving a dial to a higher number, thus lowering the headlights to normal level because passengers in the rear seats have caused the rear to descend thus effectively raising the front. I suspect most drivers don't pay attention to this feature (my Wife certainly doesn't consider it) - In her defence we rarely have rear seat passenger. Anyway, even though the lights were set at O, and headlight beams were correct, the facility to move them has to be active in case passengers are carried (I accept that). At MOT test the LH light wouldn't move. A whack with a screwdriver handle to the stepper motor go it moving so the car was passed. I need to fix it, and although it may only need a squirt of silicone spray there appears to be no 'oil hole access' or means to remove the stepper motor without removing the headlight. Headlight removal looks like it also needs front bumper removal (what joy). Anyone experienced the same problem? I'm considering seeing if the motors will move (colder weather compared with day of test) and cycling them several times - it may cure the problem? Or, of course, it may end up with headlight permanently in the 'pointing at the ground' position.
which works whether I'm driving on the left or right and which I'm equally sure will cost an absolute fortune to fix if (when?) it goes wrong
