Globalti
I've had a good eight years of use out of my Ksyrium SLs, which I got almost new from somebody on here. Now the rear rim is worn out. The front is perfect and I don't want to throw away a great wheelset for the sake of a re-rim but Mavic do not encourage people to rebuild their wheels and they destroy all spares five years after a model is discontinued. This is like red rag to a bull to me so I managed to source a new Ksyrium Elite rim, which is identical to an SL rim except that that flattened bits between the spoke beds are silver, not black.
My usual method of re-rimming a wheel is to tape the new rim alongside the old and transfer the spokes over one by one. However this won't work with the Ksyrium because the proprietary nipples are rusted solid to the spokes and screwed into the rims with thread lock. I bought 20 new spokes and can see why they rust; the area of spoke inside the rim and nipple is not anodised, nor is the inside or threaded area of the nipple so you've got a perfect moisture trap with unprotected aluminium and steel. Trying to unscrew the nipples (reverse thread as well) they just break up like rotten teeth so last night I hacksawed the first spoke, which parted with a loud bang, so great is the tension.
Now the wheel has gone out of true radially and I can't get the new spoke nipple to engage with the thread as there isn't enough length available. So I've reluctantly decided that I'm going to have to dismantle the old wheel completely and rebuild from scratch. I've already discovered that the wheels are manufactured so precisely that the threaded holes in the rims are actually orientated in the direction of the spoke, thus ensuring as straight a spoke as possible. This is going to make rebuilding a little bit more awkward especially as more spokes go in and I have less and less wiggle room.
Here's a pic of a Mavic spoke. Great engineering but annoyingly different from everything else:
I was thinking of putting a light smear of white grease inside the nipples where they press on the mushroom at the end of the spoke, just to help with smooth rotation and avoid spoke wind up. I also need to finish the build off with Loctite 243 on the nipples, which worries me as it will take time for me to get the wheel trued up. So this is going to be a bit of a challenge but I'm determined not be be defeated.
Has anybody got any helpful hints or tips? Oh, and has anybody found a way of renovating the rather fragile red clear lacquer on the hubs? It's definitely not anodising but a lacquer, sprayed on. Nail varnish doesn't work.
