RedBike said:I can imagine that regularly swapping from gears to fixed will become a pain. It will effectively mean completely re-building the bike each time.
At £375 it strikes me as a little costly for such a heavy alloy frame.
Perhaps the Surley Cross check, Cotic Roadrat are worth a look?
(I'm sure they'll be loads of others too.)
These frames are steel and spaced so they can fit either a 130 or a 135mm hub. They take gears (even discs) yet they have track ends.
Crackle said:Looks interesting Yenners. I like the concept, hardly difficult to convert if you intend to do periods of fixed, periods of gears but not one for a 'I fancy...' urge. What's the thinkin' then?
