swee'pea99
Having (I believe) now fixed the cotter pin problem, I've run into the previously unsuspected back brake problem, whereby the left hand brake block rubs constantly on the rim because the pivot where the arm is supposed to revolve (the oily-looking one in the middle, below) is sticky.
I've tried working in 3-in-1 and PlusGas - lots of liquid, lots of working back&forth, and it does shift. It's not like it's seized up. But it doesn't move anything like as freely as it should, so the spring's unable to pull it back from the rim. (The arm on the other side does all the moving.)
I'm out of ideas - any tips much appreciated.
(Oh, incidentally, I can't remove the whole unit from the bike - some weird French fitting, all seized up.)
