SkipdiverJohn
Deplorable Brexiteer
- London
I've recently picked up an interesting, but as yet unidentified, Raleigh rod-braked 3-speed roadster.
I'd hoped to have some pics up in the "show us your Raleigh" thread by now, but unfortunately an essential front tyre change has revealed the fork is a bit misaligned and needs some remedial "persuasion" whilst solidly clamped in a big bench vice, as the wheel is not sitting square & central between the blades when correctly fitted in the dropouts. The wheel had been misfitted on the piss many years ago by the look of it to allow the rod brakes to work. This is not the usual fork bent back, bike ridden at speed straight into a solid object that wasn't big enough to see, sort of problem. This is more subtle, and wasn't visually obvious.
It's not a major problem, and the bike was super cheap, so I'm not going to cry about it. Anyway I digress....
This Roadster is a little curious, and I'll describe it as best I can without pics in the hope someone has got one the same and can positively identify the model:-
Fully brazed frame (not bolted-in seatstays), size 23", bronze green paint just like an old Land Rover, moderately slack geometry - not super-slack. Steering lock on nearside of fork and receiver bracket brazed to lower head tube. Yellow sticker declaring frame made of high tensile steel tubing on seat tube.
Wheels are 26" special Raleigh section steel rims, which take ISO 590, 26" x 1 3/8" tyres - NOT the 28" x 1 1/2" ISO 635 size normally found on rod-brake roadsters.
Transmission is a '73-dated Sturmey 3-speed, AG hub, which I believe is an AW internally but with dynohub generator. Chainset is Raleigh cottered, with the Heron, 46T on the front and 19T on the back. Normal SA trigger shifter. Fully enclosed all-steel chaincase (the chain and sprockets are still like new inside!).
Accessories are full enamelled pressed steel roadster mudguards, Raleigh decal on rear mudguard. Sturmey dynohub lighting with a DBU battery storage canister bolted to the seat tube. Pump pegs on down tube, Brooks sprung roadster saddle, North Road style bars with rod brake fitments. No rear rack fitted. Alloy propstand, which might be dealer-fit.
I weighed the bike before I started working on it and it weighs around 41lbs with the lights and DBU fitted. Without these it's around 39 1/2 lbs, which is quite a bit less that the usual quoted 45-50 lbs for rod brake roadsters. My best guess is that I have got a Dawn Tourist, but I'm not 100% sure about this. Does my description ring a bell with any other Raleigh roadster owners?
