graham bowers
- NW Leicestershire
Hi
The question is how much margin is there in recommended max tyre pressures please? Context is:
I recently bought a Dawes Kingpin of 1980 vintage and replaced the tyres and tubes with new ones as a precaution. Both tyres and rims are marked with the French size 500a, which is 440 in ETRTO language.
The new tyres are Shwalbe HS 166 size 37-440, which are within a mm on width as the old Michelins that were on it from, I guess, 1980. The marked max pressure on the new HS166's is 60 psi, so I pumped them up to 60 psi with a trackpump that has a pressure gauge that has been checked (it agrees with the pressure sensors on my wife's new (company) BMW). I've ridden probably 100 miles on the tyres over the last month.
I used the bike to go volunteering last Wed and it was locked up all day within my sight. There was a loud pop around lunchtime and the rear tyre had popped off the rim, bursting the tube. The bead of the tyre is now damaged, see pic. I replaced the tube and the tyre just popped off the rim again but straight away.
I clearly need to replace the tyre but am reluctant to replace it with another HS166, and am also concerned about the front one, but would be OK letting some pressure out as most of the load is on the back one.
Does the panel think I optimistic expecting to be able to pump it up to the max recommended?
Graham
Graham
