Another question on gearing
Paul_L
I'm about to convert from a Triple (30 smallest ring, 25 tooth largest sprocket on casette) to a Compact (34 on smallest ring, 25 cassette).
Now i think i understand gear ratios, so basically i'm going from a lowest gear of 0.83 to 0.73.
I occasionally use the smallest gear on the Triple, but not too often and when i do it's only really on lumpy bits greater than say 13%.
Question is, how much of a noticable difference will this make?
And what's less of a stigma; spinning up a steep hill in a triple or walking up a steep hill with a compact ;)!!
twozeronine
Middlesex
I'm sure others will provide more info on gear ratios etc., but just to add my 2p, I've recently switched from a triple to a compact (with a 10 speed, 12-25 cassette), and haven't had any problems. It took a bit of getting used to though, to find the gears I'm happy with.
The steepest hill near me is about 20%, and I don't have any more of a problem getting up it than I did on my triple, so you should certainly still be able to get up those hills, you just don't have the luxury of having the extra granny gears. :smile:
TheDoctor
The TerrorVortex
Personally, if I ever used the lowest gear on a triple I'd not swap it for a compact.
Said he, with benefit of hindsight. I did the swap you're looking at and I wish I hadn't.
I'm forever swapping chainrings to get the right gear.
raindog
er.....
France
What difference will it make?! It will make it harder to ride up the same hill you ride up with 30-25.
And you'd rather push a compact up a hill than ride a triple up????? But why not get a compact with 27 on the back, which I guess will give you a similar bottom gear?
Globalti
Somebody once wrote on here that mountain bike gears have no place on a road bike; I was outraged at the time but have since come to understand what he meant. For loaded touring and off road riding, sure, use a triple but as he wrote, using a granny ring ruins the finesse and subtlety of road riding. With a 34 inner ring and an 11 - 27 cassette I can get up everything around here without the need to walk. My cycling buddy has a triple and it makes no difference to our speed up hills or ability to climb them.
Paul_L
Paul_L
I'm finding i'm using the lowest gear less and less often so i think the time is right to move to a compact
No, of course i wouldn't. That comment was made in gest due to the snobbery of some folk who turn their noses up at a triple.
I'm mindful to go with the 11-27 option at the rear.
Panter
Just call me Chris...
+1 to this really. My new bike has a compact, and I was worried about the hills initially, but I've had no problems so far
lukesdad
It might on the downhills !
zacklaws
Beverley
I have both a traditional double and a triple, and likewise it makes no difference to the speed as its always the same climbing steep hills 3- 5 mph, but what is difference is the cadence, on a steep hill, I can be down to 30rpm on the double, teethering on the point of falling off on the steeper hills, but in the 60's on the triple and when I get to the top, far fresher on the triple than on the double. And once I hit a long 20%+ hill, I can only manage it on the triple, one day I plan on getting a compact double and that should then become a good all round bike for club rides when I do not know the route before leaving home and may have some big hills to climb
