Brandane
- Costa Clyde
I decided to take the 1.7kg suspension fork off my Trek MTB for the summer (??!!) and replace it with my 0.8kg carbon fork. A job I have done many times in the past. So I was surprised to find movement when applying the front brake, as if the cap bolt was loose.
Dropped the fork out a bit to make sure the lower bearing was seated correctly. It was. Still movement.
Noticed some slack in the wheel axle. Took it apart, cleaned bearings, races, re-greased and put it back together. Still the same.
Scratched head some more. Light bulb moment, maybe it's the brake disc that's loose. Tried moving it by hand, seemed ok.. But took wheel off, slackened the lock ring, greased the threads and re-tightened it. Success!!
A 15 minute job turned into an hour and a half. But at least it's done, and I have serviced the front axle at the same time.
