gaijintendo
- Scotchland
On my Kaffenback 2 I tried to fit a LifeLine Narrow Road Mudguard Set from Wiggle. It described itself as "42mm (28-32mm tyres)". Here they are, <£16 and quite adjustable - every leg is independently fixable. Single legs at the front makes it quite easy to fit at the front at least.
I have pretty much this issue, apart from I seem to be able to change rings... it is just - the "band on" part is pushing the mudguard.
If I had a slightly smaller set, surely that wouldn't fix the problem?
I dropped from a perfectly serviceable 32mm M+ to a 28 in preparation for some guards...
So... dremelling in the middle... where it is structurally sound. That's not going to work, is it?
Putting a spacer on the chainstay bridge to push the bottom back a bit - might that help?
I had raceblades on previously, and thought I would treat the bike this winter. The reality is, I got to this point about a month ago, and have just not been able to face it - and have been riding my fixie to fill in... and enjoying it. My commute has just doubled for a while, and I fancy changing gears a couple of times...
Any suggestions to remedy appreciated. Even cheap ways to go 10 speed single fronts cranks
