MajorMantra
- Edinburgh
Please bear with me, this is rather lengthy...
I'm on the verge of buying a new bike and have almost come to a decision but I'm having trouble determining the best frame size for me. The bike I've (almost) settled on is the Ribble Sportive Racing that everyone's been raving about lately. This is the geometry:
I'm having trouble choosing between the 49 and 52cm frames. From their height table I would definitely want the 52 as I'm 5'8.5", but what concerns me is the TT length. For comparison, these are 3 of the road bikes I've ridden a reasonable distance on over the past few months:
Genesis Flyer - 54.5cm TT - seems quite comfortable and offers a reasonably aggressive riding position
Cannondale CAAD5 R900Si - 56cm TT - a bit stretched, I have problems with my arms stiffening up after riding for a while. I tried switch to a shorter stem (90mm) but still felt stiff.
Old hi-ten lump - 58cm TT - quite comfortable. I think this is because the saddle and bars are roughly level, but I still find it odd that this works as well as it does. It makes me wonder if I'm misunderstanding my problems with the Cannondale - could it be something about the ride quality rather than the reach? Or is it the rather wide bars on the Cannondale causing the problem?
To complicate things even more, I tried the Competitive Cyclist fit calculator and these are the numbers it spat out:
Can anyone offer an insight?
Matthew
I don't know if I should take any notice of this, but it seems to think I ought to have a really small frame.Measurements
Inseam: 81.2
Trunk: 64.25
Forearm: 33.0
Arm: 60.5
Thigh: 56.5
Lower Leg: 52.0
Sternal Notch: 142
Total Body Height: 174
The Competitive Fit (cm)
Seat tube range c-c: 52.6 - 53.1
Seat tube range c-t: 54.2 - 54.7
Top tube length: 53.1 - 53.5
Stem Length: 10.7 - 11.3
BB-Saddle Position: 73.0 - 75.0
Saddle-Handlebar: 50.8 - 51.4
Saddle Setback: 4.1 - 4.5
The Eddy Fit (cm)
Seat tube range c-c: 53.8 - 54.3
Seat tube range c-t: 55.4 - 55.9
Stem Length: 9.6 - 10.2
BB-Saddle Position: 72.2 - 74.2
Saddle-Handlebar: 51.6 - 52.2
Saddle Setback: 5.3 - 5.7
The French Fit (cm)
Seat tube range c-c: 55.5 - 56.0
Seat tube range c-t: 57.1 - 57.6
Top tube length: 54.3 - 54.7
Stem Length: 9.8 - 10.4
BB-Saddle Position: 70.5 - 72.5
Saddle-Handlebar: 53.3 - 53.9
Saddle Setback: 4.8 - 5.2
Matthew
literally - i.e. ONLY consider whether it is the right size - not whether it is a comfortable bike generally, whether you like the aggressive riding position, whether the saddle is the same height as the bars, what the ride quality is like, etc etc etc., because so many other different factors can influence those.
