Scilly Suffolk
I took my bike to the LBS after the BB started making an ominous clanking noise and the drive side kept coming undone: a bearing had gone.
As the drive side was undoing itself I assumed I had an Italian BB, despite it being a handbuilt English frame (late 80/early 90 vintage).
The LBS advised that I was only half right: the BB was originally English (68mm shell) but the drive side was Italian threaded; presumably it had been cross-threaded and recut at some point.
I had intended to replace the open BB with a sealed unit at some point and they suggested I buy an Italian BB and use the English cup on the non-drive side.
After thinking about it, I am less sure this would work: wouldn't the 70mm Italian BB be too wide for my shell or is there enough slack to tighten the English cup enough?
I probably doesn't need stating, but I have little practical experience of BB...
Thanks & regards.
Thanks & regards.
