Torvi
mr poopmechanic
- Wellingborough
i find myself that if i use smaller gear on front i only use about 4-5 hardest gears out of rear, only on big front cog i maybe use 8 of them, having 10sp is kind of like a waste of gears
there are hills everywhere around me :/ average 850ft climbing for 20 miles tripLet your legs be the judge. You'll be glad of those lower gears when you get to a hilly region.
i already changed it haha sorry :P850000 foot of climbing? Do you live in the Himalayas?!
front is standard compact as in 50-34, rear is 11-32The obvious first question would be what gears are you using? IE What is at the front? 53-39 50-34 or some thing else, then what cassette is on the back 11-28?
That's quite a spread, would be well worth changing the rear to 11-26. I hated the 11-32 on the CX bike as I used it mostly on the road. You would probably need a new chain.front is standard compact as in 50-34, rear is 11-32
it's a new bike with sram apex on it, if there would be a way to kick off biggest sprocket and put another like 9t sprocket id gladly do itThat's quite a spread, would be well worth changing the rear to 11-26. I hated the 11-32 on the CX bike as I used it mostly on the road. You would probably need a new chain.
that's exactly what im debating on right now. if i should go for 11-28 or stay few months and see how it goes on 11-32You won't get a smaller sprocket than 11T. But you will easily find cassettes with closer ratios and a 26 or 28 largest.
I'm the opposite - I rarely get near 50/11 on my Apex equipped bike.
I guess you need to figure out whether the benefits of closer ratios are worth the faff of fitting a new cassette and the loss of a crawler gear for when you do hit a monster hill when knackered.
