Alternatives to buying cable rub protectors - sellotape?
Welsh wheels
Lycra king
South Wales
Having some cable rub on my aluminium frame, was going to buy some of those adhesive cable rub protectors but being a frugal sort of person I thought that something around the house might do the trick. I might just stick a strip or two of sellotape under the cable. Anyone ever used sellotape for this? Or is it a bad idea to stick sellotape on the paintwork?
Twilkes
I've used electrical tape, seems fine so far. Black tape and frame so not really noticeable.
CanucksTraveller
Hertfordshire
You could, it's just that sellotape will dry out eventually and fall off before those gel stickers will, and you'll have that crunchy residue left. Not the end of the world, it can be removed with spirit. It won't materially damage the paint. I'd double or triple up on sello tape, it's much thinner than the gel pads. Electric tape is better.
Venod
Eh up
Yorkshire
I use Gorilla Clear Repair tape
Same here.
The only thing with cable covers/rubbers, is that where you get grit involved, you do need tape on the frame as that still rubs the paint off.
PS - if ever removing heli-tape, make sure you warm it up first with a hair drier before trying to remove - it will pull your paint off.
