I have a Pinacle Arkose 3 and at the end of last year the BB started to make a clunking noise once per revolution and I replaced it, solving the problem. Only a few hundred miles later, the new BB is doing the same same thing and I would like to replace it with a different and hopefully more long lasting model.
I don't think I am doing anything wrong to cause the problems, certainly not anything that I haven't done to any other bike I have had and I wasn't even cycling much over the bad weather this winter.
The BB is an FSA Megaexo BB-4000 and the problem is that I have read that I won't be able to do change to a different BB without changing the crank, because it is made for a 19mm spindle. Do know if that is true?
I am not much of a mechanic, so I'm not keen on taking the thing apart and replacing the bearings.
Any advice or suggestions?
Thanks in advance,
Billy
Thanks in advance,
Billy
