roscco
- South Somerset / North Dorset
Hi,
i currently have a Carrera Vanquish road bike, spec:
Frame Material: Aluminium <li>Frame Size: 21-22 <li>Gears: 16-20 <li>Gender: Mens <li>Suspension: Rigid <li>Frame Size (cm): 51 - 54 <li>Brake Type: Dual Pivot Caliper Brake <li>Chainset: Truvativ Tour Compact <li>Forks: Lightweight carbon fibre fork with 1-1/8 alloy steerer <li>Frame Colour: Black and Red <li>Frame-: Lightweight double butted 7005 semi compact Aluminium <li>Front Brake: Shimano Tiagra Lever, Tektro R720 dual pivot caliper <li>Front Mech: Shimano Sora <li>Gear Shifters: Shimano Tiagra 18 Speed <li>Handle Bars: Kalloy Alloy Oversize 31.8mm drop <li>Headset: Semi Integrated Ahead Set <li>Hubs: Shimano WHR500 Wheelset <li>Number of Gears: 18 <li>Pedals: Wellgo Alloy with Toe Clips (now upgraded to Shimano SPD)<li>Rear Brake: Shimano Tiagra Lever, Tektro R720 dual pivot caliper <li>Rear Mech: Shimano Sora <li>Rims: Shimano WHR500 Wheelset <li>Saddle: Carrera <li>Seatpost: Kalloy Alloy 27.2mm <li>Stem: Kalloy Alloy oversize 31.8mm <li>Tyre size: 700 x 23C <li>Tyres: Continental Ultra Sport <li>Wheel size: 700C
Its done me brilliantly for the last two years but before wear and tear sets in, i fancy a change and wondering if its possible to upgrade to a better spec bike for around £500 -£600? I dont have a great knowledge of the spec, so its listed above in the hope someone will be along who knows their onions and can advice on something better?
Thanks in advance.
Thanks in advance.
