ally to steel bonding question
stuee147
north ayrshire
i have a very simple question but i fear the answer may not be as simple.
i would like to use some aluminium in part of my trike im building, but im not sure how i can bond ally to steel it is something that i would like to try im not planing on doing it alot so i dont want to spend lots of money on equipment and gasses to weld it. i was thinking more along the lines of fibreglass ?????
would this work ?
or is there an alternative method ??
i will add iv tried my hand at brazing and iv just never been able to get it to work so id rather not try that lol
stuee
Lanzecki
Bolts or very expensive glue.
Welding's not gonna work. Brazing's the same.
What's the parts? Load bearing?
stuee147
stuee147
north ayrshire
i want to try and stay away from bolts and its not really load bearing iv not got any set designs but i was thinking of the seat frame and possibly the bottom bracket do they do a special glue ??
They will corrode each other won't they? (galvanic reaction?)
i was hoping someone may know i know if you bond ally with carbon fibre you need to be careful as they can react apparently
Nigeyy
Assuming you are thinking of some part of the structural frame, and as someone who had a Raleigh Technium mtb with steel/alu bonding, my recommendation would be..... don't. I'm assuming Raleigh had greater resources to do this, and they failed (my frame -admittedly after thousands of miles -came apart, and I wasn't alone in that). They did use an epoxy bonding for the frame joint fwiw. There's a reason why they stopped making them.
