Peter Salt
Bittersweet
- Yorkshire, UK
I have some bad experiences with using alloy stems on carbon steerers. Specifically, stems that provide relatively low internal surface area - due to various cut-outs - leaving nasty marks on the steerer, despite applying the right bolt torque.
I'm doing a new bike build and once again came across an alloy stem that I really like, that seemingly hasn't been designed with carbon steerers in mind (cut-outs wherever possible). Said stem is available in 1-1/8 as well as 1-1/4 inch versions (steerer OD). The steerer on the bike is 1-1/8 OD.
Would it make more sense to get a 1-1/4 version stem, alloy 1-1/4 to 1-1/8 shim, and put that on the carbon steerer? Instead of fitting the 1-1/8?
Never used a shim like that before, any bad experiences out there?
