shouldbeinbed
Rollin' along
- Manchester way
Bugger. Refitting a rear rack and the Allen bolt head has sheared, leaving the body inside the frame & not protruding at either end so I can't get a hacksaw onto it to put a notch into it to screw it out.
Do I drill it and find someone to rethread the hole?
help
help
.... the reality when I've used them is that you have to use a drill that's so thin that is get hot and welds itself into the hole its drilled, snaps off then you have to drill out a broken hardened drill bit with a slightly bigger drill.... that then goes blunt itself because its drilling a substance harder than itself because the broken one is heat hardened......................................OR the drill goes off at a tangent and comes out the side of the item you trying to remove the thread from.......
