SatNavSaysStraightOn
Changed hemispheres!
- ɐᴉlɐɹʇsn∀ 'ɐɹɹǝquɐƆ
OK needing some assistance.... I have all the symptoms of a frayed gear cable (again
) but having looked at the cable, it is not frayed at all. It is not rusty, it is still well lubed, and actually looks like it is new, which is a real shame because I went out and bought 2 new ones yesterday completely convinced I knew what the problem was! So I am at a loss again...
Cassette has done around 3,000km, new chain 500km ago. Both are kept clean to the point you can see it was a silver cassette etc - washed and lubed after each ride (necessary because of the lane I live down). Cassette really does not worn but I do have a spare one just in case.
Symptoms: slipping gears on any chainring but usually the same 3 or 4 sprockets on cassette & temperamental gear changes (sometimes happens, sometimes does not, sometimes needs 2 up 1 down just to get to 1 up etc), stiff switch on the right shifter in certain gears only (and not always either) and often the lever is not returning to the vertical position....
![Sad :sad: :sad:](/styles/default/xenforo/smls/sad.gif)
