Innes
Shot, Over!!
- Leuchars, St Andrews, Fife, Scotland
View attachment 376904 Hi all, picked this Inflator and a pack of cartridges up yesterday at Britain's favourite supermarket. I've not tried it yet but it looks like a good bit of kit for an emergency, doesn't take up a lot of room in the saddlebag either. Anyone else used one of these.
The canister will be pierced when you screw on the inflator. If you pierce the canister all of the co2 will be released....Bought this.
Unable to pierce the co2 canister.On examination doesn’t appear that there’s no means of piercing the canister.
Obviously defective.
I have one, it's very good, just remember not to screw it on to the valve too tight if you have to use it, if you do, and you have 2 piece valves, the core will likely unscrew as you try to remove it. You only need to screw it down far enough to form a good seal.View attachment 376904 Hi all, picked this Inflator and a pack of cartridges up yesterday at Britain's favourite supermarket. I've not tried it yet but it looks like a good bit of kit for an emergency, doesn't take up a lot of room in the saddlebag either. Anyone else used one of these.
When you screw in the red knob it'll probably have a point that pierces the cartridge.That’s what I did,but there is nothing in side the head to pierce the canister.
Obviously a defective one
The red knob is just a control screw, make sure you close it before you screw in the CO2 cannister at the other end. Screwing it in will break the seal if it doesnt its pin is broke/missing.Tried that.Dug my old brass inflator out of my trash bin.Works perfectly. Bought this one as it is lighter and fits in my tool pack Thanks for your replies
Blimey how small are your arms? I thought that was just a sleeve for the gas cartridge.Not impressed with the arm warmers the reflective bit is not breathable and not insulated, went from holding sweat to cold last night .
