biggs682
- Northamptonshire
For Sale Aende single speed Road bike
A 23 1/4" or 59cm sized frame from centre of crank to centre of seat pinch bolt so suitable for aprox 5ft 8 upwards and measures 22" or 56 cm along the top tube cenrtre to centre and has a stand over height of 33" or 84cm .
Frame is made with Reynolds 531 professional tubing with neat shot in rear stay and typical "Pongo" drilled lugs , this was originall built for time trials as only 1 down tube boss a short compact wheelbase , paintwork is best described as honest with a few battle scar marks but no dents , useable as is or could be refinished . Some of the decals are missing and some are starting to peal .
Gearing is 52 x 16 but the crankset is an unknown model shimano triple with the inner ring removed and a new 16 tooth rear wheel spacer kit fitted along with a new chain and a trial tech chain tensioner . The wheel set is a specialized axis classic that were fresh of a new bike that had been uograded , fitted with a new set of 700 x 25 Vittorio rubino's.
Frame has 1 set of bottle cage mounts but no cage , nice long alloy seat post that is free to move and adjust as is the 110 mm quill type stem . New brake calipers fitted along with new control cables and aero levers .
I built this as a bit of fun but sadly with 10 bikes in the garage this has to go .
Asking £195 collected from NN8 Wellingborough postcode or could send via a 2 day courier for an extra £25
