Advice on handlebars
Hels87
Hey all,
I have a pinnacle neon 4, I'm looking at changing the handlebars to drop bars - is this a project a lay person could easily do at home? I presume I would have to get new brakes to install as well?
Thanks in advance
H
Nick Saddlesore
London
The short answer is no.
The Neon, I believe, has hydraulic brakes and the equivalent of a Tiagra 10 speed drivetrain. Tiagra drop levers don't do hydraulic, so you will at least need to buy 105 levers - 11 speed, so I think you'll just have a redundant click, unless you also buy a new rear mech, cassette and chain. You will probably need new hydraulic hoses, and will anyway have to do a complete brake bleed. You will probably also need a different stem. This is all getting uneconomic - better to sell the bike and get a drop bar bike with the correct geometry.
A possible alternative is to buy some bullhorn bars and use your existing levers. Might want to change stem, but no brake bleed and easy to do.
