I have a Kona Koa MTB, 1996 vintage. I've never been too good at looking after it  , but after reading on here about how easy most maintenance jobs are I thought I'd check the bike over and see what needed doing.
As I had expected, the chain has stretched. Job 1: replace chain.
But are the sprockets OK? No, they're not. Worn, broken, and damaged teeth. How has the bl**dy machine kept working for so long? Job 2: replace cassette.
While I'm at it, I may as well check the chainrings. Oh, sh*t, they're worse than the cassette. Job 3: replace chainrings.
Now, I've never done anything like this before, and my toolset is basically Allen keys, screwdrivers and spanners, so I need the specialist tools as well as the parts. This is where you lot and your amazing breadth and depth of knowledge and experience come in. Please cast an eye over my shopping list, and see if it's reasonable.
The bike is a 21-gear triple – 42/32/22 up front and 11-28 on the back. Square taper bottom bracket and a freehub rather than freewheel. I'm happy to keep it like that, or as near as dammit. So I was thinking:
As for tools:
Will these parts and tools do the job(s)? Have I overlooked anything? Are there better options?
I was also wondering about the bottom bracket. It seems to be fine. No looseness, and no nasty noises. But, as I'm doing all the rest of the stuff, should I replace it anyway? I don't know if this is good practice, or not. Advice, please.
If the consensus is to fit a new one. I was going to go for the Shimano UN26 68mm Shell English Thread Sealed Cartridge Square Taper Bottom Bracket 113mm, and I'd also need an IceToolz ISIS / Shimano bottom bracket tool.
Amazingly, by shopping around, I think I can do all this for a little over £100, which I suspect is considerably cheaper than my LBS would charge.
- Shimano Alivio Chainset square taper M410,
- Shimano HG 50 7-Speed 12-28 cassette (I know this will reduce the top gear from 93” to 85”, but I don't ride the bike for speed, so it's not a problem),
- KMC X8 93 chain (the page says that 8-speed chains will work on a 7-speed system).
As for tools:
- Park Tool cassette lockring tool,
- Xtreme chain whip,
- Park Tools Chain Brute chain tool,
- Ice Toolz crank removal tool,
- Park Tool anti seize assembly grease.
