Cyclopathic
- Leicester.
I'm putting the crank arm back on to the bottom bracket and I have never done this on this type of set up before. It's a carrera mountain bike and the crank is secred with an allen bolt straight into the end of it.
Should I tighten it up absolutely as much as I can so that it is pulled onto the taper as much as it possibly can be or does this run the risk of putting too much pressure on the bolt and dethreading either it or the axle.
Thanks in advance for any ideas .
