gaz
Cycle Camera TV
- South Croydon
How the hell are you meant to do it?
i undid the nut that held the cable on the brake, and due to the spring it just poped open. so the only way i could think of getting it to be tight enough was to pull the two side parts together until nearly touching the rim and then pull the wire taught and do the nut...
is this the way other people re-set the position of there brake cable on there bike?
