Adjust stem height
Jimmy Welch
When I try to take a spacer from below my bars and lower the bar the spacer won't sit properly to the same depth as it was below plus I am unable to compress the bearings sufficiently with the spacer on top although there should be no real change in dimensions if it's on top or below , am I missing something
ColinJ
Puzzle game procrastinator!
What do you mean by "won't sit properly"?
(You do know that the top of the spacer should sit slightly above the top of the steerer, not level with it? :whistle:)
Spiderweb
Not So Special One
North Yorkshire
Can you post a pic please.
You should always tighten the top cap before you tighten the stem bolts.
J
Jimmy Welch
Hi guys just to clarify if I take one spacer from underneath the bars and place it over the now petruding post above the bars , when I try and screw down the top cap it doesn't compress the bearings enough
Is the star fangled washer (which the top cap screws into - is it too near the top ? - you might have pulled this up.
Before you take put on the top cap, is there still a couple of mm that the spacer sits above the steerer tube ?
J
Jimmy Welch
Hi yes there is a few millimetres from spacer to top tube I'll check if star washer has been pulled up cheers
J
Jimmy Welch
......but when I return the spacer to its original position underneath everything tightens up perfectly ,
Ming the Merciless
There is no mercy
Inside my skull
You need to workout out why , the single spacer must be sitting not as proud of steerer tube as stem is when arranged other way round. So why is that , that’s what you need to look at.
J
Jimmy Welch
Yes but there's a clear gap but I can full tighten down the top cap screen and there is loads of play in the bearings
