Adidas response Short Sleeve Jersey
walker
Bromley, Kent
Upon opening the bag to take a look at this Jersey it looked great, good vibrant Blue with great detail, but thats where the honeymoon ended.
I put the jersey on and also its a good fit on the arms (My arms are a little larger than most cyclist's I know) the fit around the midrift is a little too loose, its as though most of the cut is everywhere other than the zip line finish, where it seems to make the shirt pertrude from the body, making you look larger than you actually are.
On the bike, the Jersey is fine but the rear 3 pockets are not tight enough, anything you put in the rear pockets appear to bounce around and can even fall out.
Good things about the shirt are that it is really breathable, great material for Summer use, the 3/4 length Zip makes for some great air flow when needed and as the jersey isn't as snug as I like, it leaves for great movement in the saddle.
I prefer Adidas clothing over most but this one is given a thumbs down.
Rating 3/10
