Hello. I have two bicycles; one a mountain bike and the other a hybrid. The hybrid currently has static forks and the need has come to replace them with suspension forks. In itself, not a difficult task as I've done a fair bit of bicycle maintenance to date. However all my maintenance skills are gained from hands on and watching youtube alone with an engineering background. Enough bragging now
and my issue is this. I've noticed that the head tube on my hybrid is different to the one on my mountain bike as in the hybrid has a longer head tube. The top tube and down tube on the mountain bike are connected to the head tube in a single weld whereas on the hybrid, they are separate with about an inch between them. I also notice that the outer diameter of the head tube on the mountain bike is wider. I am thinking that these factors limit the options for putting front suspension forks on my hybrid. Am I correct? If so, how can i bypass this issue.
Thank you
FJB
and my issue is this. I've noticed that the head tube on my hybrid is different to the one on my mountain bike as in the hybrid has a longer head tube. The top tube and down tube on the mountain bike are connected to the head tube in a single weld whereas on the hybrid, they are separate with about an inch between them. I also notice that the outer diameter of the head tube on the mountain bike is wider. I am thinking that these factors limit the options for putting front suspension forks on my hybrid. Am I correct? If so, how can i bypass this issue. Thank you
FJB
